I took the greatest influence from Dogs and Honda Element Bed Platform | Steph Davis - High Places design, which seems to be based off of other designs as well.
I wanted storage below. I wanted modular. I needed to be able to install/remove on my own. I prefer to camp with the tailgate open, but wanted the option to keep it closed.
204398
204399
Out of the car, it folds and the legs can be removed for easier storage. They're HEAVY as they're near furniture grade 3/4" plywood. It's salvaged lumber that I had in my basement. Several pieces at approximately 23" x 47". I once used them as shelves. Before that, they were lab tables at a university.
204400
I put in the rear half first through the back.
204401
Then I can slide the other half in through the side doors.
204402
Getting closer to connecting...
204404
204405
My flanges overlap to hold the weight from above. This overlap, I hope, will be enough to keep things secure. It meant more legs in the middle, but let me split the entire thing in half.
204406
I added road case latches which will hold the two halves together while it's installed.
204407
The latch engaged and holding. There are two latches.
204408
The entire thing installed and in what I'm currently calling "Drive in movie" mode. Some call it futon mode.
More pics to follow... 10 per post it seems....
Discussion Starter #2
Continuing....
204409
Lower the front seats to get support for the bed "foot" area. Tuck them under the flap over plywood.
204410
See, right over the top. I need to ensure I add something to the whole thing... I don't like how much it overlaps. At the least, I need to add some padding to keep the wood from injuring my (new to me and without any tears!) seats.
204411
Fully laid out. The exterior panel needs more support.
204412
Picture of the short hinge in the back....
204413
Picture of the long hinge in the middle. I cut one segment off the hinge.
204414
In driving mode, it looks like this from the front.
204415
In driving mode, it looks like this from the outside in the back.
I still need to:
  • Maybe trim the front flopover piece. It might be too big.
  • add padding or something to the front flopever piece before it eats my seats.
  • Add my tie downs to secure the entire thing to the car. Planning to use the corner ties and MAYBE the seat latches in the floor. I like those locations more than the corners. I've added hardware to the platform for hte corner ties. Unsure what to do on the middle, but we shall see.
I also need to add some aluminum trim on the wood in some key locations. And I need to add something to make sure the two platform pieces don't slide apart laterally. Two small pieces of wood should do the job.
I've made adjustments to help support the tapered piece that flops out of the back. Some 3/4" EMT and strapping does the trick. Also a hole with a self tapping screw prevents the loss of the support rod. This seemed a good solution, but I may add more support - directly to the hatch lock bar. We shall see.
Also, someone had suggested wider footers to help prevent indendation. So I made some leveling blocks with 3/4" dowel in them (cut to 3/4" length) so the leveling blocks won't slip away. They're screwed and glued together.
