Here I am, back again with another concern about poor Ruby (07 EX 4WD).
For those who have seen my earlier posts, most everything is fine from the major engine work. The valves seem good, no serious shudder, only code currently active is the downstream 02 sensor (which I'm going to replace soon,) and all that.
But! I have come across an interesting set of issues. I noticed that something in the passenger side front suspension seemed to squeak. I let it go for a week or two, seeing if it would go away, but no dice. There's not really an explicit pattern I've noticed, but almost always occurs when going over rough/uneven roads.
However, upon going under for an inspection, I noticed almost the entire passenger suspension system was coated in a layer of oil- definitely fresh. Quick look deeper suggested it was coming from the lower section of the engine. Took it into my local (very sleazy) mechanic, and they said there was nothing from the timing chain cover (as I had suspected due to them having to remove it previously), but instead a pair of solenoids. They replaced those, but 2 weeks later the leak is still there.
So! I ask you, the forum- where should I begin to look for this? What could be causing the squeaking? Where is a good place to start looking for the leak? Should I just get it diagnosed from a different mechanic, the local Honda dealer, maybe? I believe the ball joints were done recently, and the shocks definitely were. Maybe thought about the CV axle? Or maybe a sway bar bushing? Thanks for all the help, as always.
