1 - 7 of 7 Posts
Hey everyone, thanks for all the help I have discovered thanks to this forum.
I'm trying to figure out which aftermarket Air/Fuel Ratio Sensor will work for my 2005 Element which is throwing P0135. I scanned the code using my scangauge II OBD II Reader and after reading LOTS of threads, i'm ready to get it fixed, however, NO one has mentioned the part number they used when they fixed thier cars with this issue.
I have found several at amazon
http://www.amazon.com/Denso-234-906..._2?ie=UTF8&s=automotive&qid=1283206921&sr=8-2
http://www.amazon.com/Denso-234-473..._3?ie=UTF8&s=automotive&qid=1283206921&sr=8-3
http://www.amazon.com/Walker-250-54...2?ie=UTF8&s=automotive&qid=1283206921&sr=8-12
http://www.amazon.com/Denso-234-900...1_fkmr0_1?ie=UTF8&qid=1283206921&sr=8-1-fkmr0
and several people have mentioned NGK sensors, but I cannot find them. Does anyone have any experience replacing this part? and know what part number I should get? Obviously I would like it to be the cheapest one, but I don't want to buy something and have it be the wrong part(bosch one that everyone seems to have used always ends up being wrong)
There has been much discussion Over the years about this. The consensus Has been to use the Honda part.
Others have tried the cheep ( read inexpensive) replacement parts with little or no success.
Dom
Dom
It hurts so much when you see it written before you...
when i first saw this thread. my first thought was hondata and turbo hehe
but i would totaly agree with the use honda part. unlike most cars hondas are pretty sensitive with after market electronics
Oxygen Sensors
The reason that you may be having difficulty locating the NGK oxygen sensors is because NGK markets their oxygen sensors under the NTK branding. See http://www.ngksparkplugs.com/products/oxygen_sensors/index.asp
You can use the NTK part finder to get the correct parts number for your 2005 EX.
I agree most Bosch O2 sensors are junk, but the Denso ones are almost as good as the NTK units. Most Honda OEM oxygen sensors are made by NTK.
1 - 7 of 7 Posts
