Hey guys, How are you doing? I was wondering if you could give me a hand with a few cables I can't figure out where to place so I can finally finish my alarm install, an Autopage c3-RS665 remote starter and alarm (for the alarm only, i'm not gonna hook up the starter), I'll list them up so I don't confuse you:
Orange: It says it's the 500mA grounded when armed wire, should I just use a ring terminal and place it on chassis ground?
Pink: Technically, it says it's what controls the 2 step door unlock, but I have no idea where to place it... I suppose I should use the green - gray/green wires from the factory alarm, use a diode and place it there (since for the power lock and unlock there is a separate harness with a green and blue cable that attaches to the white/green and white/blue in the Driver/s kick panel(.
Green: There;s this green cable that says it;s the common ground sensor for negative door pins, and that I should find the "common cable" between door pins and hook it there, but each time I read it I go "WHAT? O_O" hahahahha!
And last but not least, the white one: It's the domelight cable for the alarm, and I suppose it goes spliced into the green/red cable that's the domelight supervision, right?
Ok, I guess that's all of it, hahahaha, I'm really sorry for bothering you with this but I'm totally stuck! Thanks for any help you can give me!
Regards, Sebastian
Regards, Sebastian
