So I picked up this pair from a EOC member. I would like to do this together and hopefully it will become a sticky. As far as I know I am the first person in the USA that will install a pair on his car.
So here are the pics:
Here we see the back of the HID unit, with it's 4 prongs.
Here's a closeup of the 3 top prongs. #1 is POWER (with a red wire & a black wire on the back of the connection. #2 is a parking light (?) with a small bulb on the other side. #3 is a turn signal (?) with an larger amber bulb on the other side.
Here's the bottom of the assembly. This is the built-in ballast and #4 is apparently to the ballast. Since I am not very good with electronics I'm going to assume this is something that controls the ballast.
So...I'm stuck as this point as I don't want to take apart the lights on my daily driver and not be able to wire this up.
Any ideas or suggestions at this time would be appreciated.
I will study the other threads on this forum where the owners converted their cars via aftermarket kits.
If any of you owners have already taken apart your stock units, pics of the wiring looms and connections would be great. Also, any pics of the back of the stock headlight unit would be appreciated as well.
