I just purchased a used 2008 vehicle that came with one, 1-seat in the back (the other was removed). I have a 115 pound Great Dane and I need to strap her in with a special dog car harness onto a seat that is BIG, i.e TWO SEATS that run together (like the normal back seat of a car). The harness is ONLY crash tested if she is strapped via a 3-point seat belt, all other options are dangerous for both of us (I've called several companies). So, can and how do I find a BACK SEAT that will fit into this vehicle AND that has safety belts that will work for this vehicle? Any suggestions? Thank you so much!
Retired.
Look in your local wrecking yards for a seat.
Unless someone has modified it the existing seat does have a 3 point belt.
2008 Element EX AWD TRP
I have a dog who travels with me and gave a lot of thought to how to safely restraint it during long high speed trips. There are no DOT harness standards for dog safety restraints in vehicles.
I use a properly sized padded crate on top of one fully reclined rear seat and anchored to the LATCH connectors. A crate large enough for a Great Dane could be mounted there or on the floor.
Assuming that you believe the manufacturer, that the harness/belt combo will safely restrain your dog in their harness during a crash, the simplest solution would be to remove the other rear seat and connect the shoulder belt tongue to one of the floor anchors using a climbing-rated carabiner
