Well looks like my a/c compresser went out on me. What i was woundering if anyone else had this problem? Has anyone fixed theres? If so what shoud i look out for? Or any help i can get. I can't go through summer with no a/c in a black E. Thanks for all your help.
There is a lot of topics here on the compressor failing or the clutch failing. If you take it to the dealor you will have a high bill. Check if its the compressor or its clutch that has gone out. If its the clutch its a lot cheapier but if the compressor failed and puked material through the system it will be pricy to clean out the system and compressor replaced.
A/C question
Just wondering,
If the compressor is a likely cause of contaminating/wrecking other parts of the A/C system, and, for many, no coverage from Honda, might it not be ( to some) worth sourcing a higher quality compressor and replace it prior to the OEM part failing? Might this preventative ploy be cheaper in the long run?
