2005 AWD Element-76,000 miles. I am hearing a low frequency noise,(front end) when I turn left or right especially left, at slow speed, ex. turning into my garage. Just started about two weeks ago. Help???
I would check the power steering fluid. A lot of times when it starts running low it will make a little noise. You have a 2wd so that rules out the rear diff fluid. I am sure someone else will chime in shortly. Please update us on what it is whenever you fix it. We always like to know.
Welcome to the club!
Now that you have filled in the profile...
It's the rear diff fluid.
fluid change solves noise
I just got the rear diff fluid changed and it solved the problem. Thanks for the advice.
How does the rear diff affect a noise coming from the front end? I'm curious because I'm having the same issue.
