1 - 20 of 42 Posts
2007 Acura TSX 7 spoke wheels. (but this was a long time ago for me)
gotta be a list like this already. offset would be nice too.
A couple of mods have seen this thread, and it has not been moved yet.
I havent found a thread like this, so it can stay. OP is looking for Honda
or Acura rims on the E. I agree, though, that if you are going to post
your OEM rims, post ALL the specs. Offset is so important when dealing
with rims!!!
The OP can go through this thread, http://www.elementownersclub.com/forums/showthread.php?t=23877
but it only had rims that are 18" or bigger. There are a ton of OEM rims that are 16 and 17inches
that will fit on the E.
the tire size is completely wrong. That was *i think* a year ago... It was 225/40/17. It will make your speedometer way off
Acura RSX 16x6.5's, +45, graphite
Got these off CL for $200. They were in really good shape. Think they're off 06 and up RSX base models. I wanted to stay as stock as possible and these were direct swaps with correct offset.
I dupli-color'd them graphite. Don't think it will last as they already have a few nicks from mounting. Tires are General Grabber HTS 225/70/16.
Cheers
Do other Honda rims interchange with E?
Just purchased an Element LX 2011 and I am looking for a set of four extra rims.
Are there other Honda models that have rimes that interchange with the Element?
I want to put a set of studded tires for the winter on other rims.
Moved your thread into here. Some answers in here. There are other links in
here with even more answers with specs. Here is another thread to check:
http://www.elementownersclub.com/forums/showthread.php?t=1557
Your best bet is to get a set of E LX steelies and use them for your winter
set up. Several people on here have done it.
'05 stock rim substitute?
We just bought an '05 in May- since we plan on at least 10 years for this one it's time to get rims for the Nokian snow tires. Will CRV or Pilot rims fit? I've searched through the forum without success. If you know a link to the answer I'd greatly appreciate it. Thanks.
Here you go.
1 - 20 of 42 Posts
