1 - 20 of 69 Posts
OEM Headlights how to convert to JDM Headlights
Wow! I finally finished! Sorry for the delay..
Well here’s how to do it step by step.
There’s a Thread here somewhere that shows you how to install your fog lights. so pretty much you can get the idea on how to remove your headlights from there.
Note: Remove the metal parts that is screwed on top of the headlights.
#1) I used my oven to soften the adhesive, by setting the temperature to 200 degrees and wait until its ready. (don’t forget to place a small towel on top of your broiler pan).
#2) when ready, placed one headlight inside “CAREFULLY” inside and wait “3 or 4 MINUTES”.
Discussion Starter · #2 ·
#3) After heating it up. You’ll need a screw driver or anything with flat head to split the headlight clear lens from the frame. (the adhesive should be soft enough to split the headlight)
Discussion Starter · #3 · (Edited)
#4) I spray painted the headlights housing with "Black Gloss". I did about 3 layer of pray paint. (The results was perfect! Nice and shinny!).
#5) After spray painting both headlights. its time to put them back together. You can use your belt to hold them together or some clip.
#6) After putting them together, I put some black adhesive on the gap to make sure that I wont have any leak.
#7) Check and make sure all the gap are filled with adhesive all around it.
#8) wait 1 hour to let the adhesive dry before you take the belt strap or clip around it.
#9) Congrats! your finish! all you have to do is install the headlights back to your "E".
#10) Your Welcome!
i wanna keep it matching with my side marker. :grin:
Discussion Starter · #13 ·
No problem MIKE!
Permatexs (Black silicon adhesive sealant)
Congratualtions, E_Ride. Nice work and even better documentation. I'm going to have to do this one, too. I'll do Shen's side marker blinky mod at the same time.
Elemen-O-P said:
Wasn't it a helluva lot easier than you may have originally thought!?
If anything, its a big confidence booster because you did something that wasn't a "bolt-on" mod.
And isn't this huge? I can remember tearing apart the Pinto that got me through college with nothing more than a Chilton's to guide me. When I put it back together, it started the first time and I only had 4 miscellaneous bolts left over. I was fearless after that.
Discussion Starter · #18 ·
"NO" You dont have to..
1 - 20 of 69 Posts
