1 - 2 of 2 Posts
I purchased a used OEM hitch and it is missing the left and right stays as well as the side plates and bolts. Has anyone ever installed an OEM hitch with replacement hardware for these parts? If so, what did you do or where did you buy it?
Thanks!!!
You can make that stuff if you're handy. If not, you're in quite the pickle. I'm not sure you can pick that stuff up anywhere separately. I'd find some appropriately sized angle iron and flat plate and drill some holes. Use Grade 8 or better hardware. Home Depot or Lowes should have some stuff to look at.
1 - 2 of 2 Posts
