1 - 13 of 13 Posts
hi folks,
back when we had our '04 E, the maintenance light would come on based on mileage(every 7500 miles, I think?)
Now they have changed to the monitored method, which i am familiar with as it is on other vehicles I own.
my concern. we have 1200 miles on the 2010, and it just droped to 80% oil life left? i don't really like the apparent 10% increments it uses, and 20% in just 1200 miles? no dusty conditions, mix of highway and city, no stop light races with Scions:oops:
its this normal? does it drop quickly at first, just start leveling off? at this rate, it will tell me to change the oil at 3000 miles!
thanks.
What has the weather been like ther ein Ohio? Cold weather results in unburned fuel contaminating your oil and lower gas mileage. Unless you drive long enough the oil does not hot enough to evaporate the contaminants.
hi capt.
since we picked up the car two weeks ago, it has been above 65 degrees every day....rain maybe 3 times during that period. my wife drives the E about 20 miles each way, combination of interstate and streets, so there are very, very few short duration trips in the vehicle.
Possibly but I doubt it. Let us know when it reaches 15%.
From reading on the forum it appears that most see the first oil change notification at about 3000 to 5000 and later notifications will show more mileage (usually around 6000) between changes.
Mine is doing the same thing. I have about 1600 miles on mine and I'm at 70%.
hi folks,
thanks.
Break-in period I am assuming
It might be a break in thing since it has such low miles on it. The oil percentage is just a simple calculator of how you drived to how many miles that is how the oil meter works. It wont go by dusty or actual oil quality.
Discussion Starter #9
mine is starting to level out now. we have 3100 miles at it just went to 60%. I will probably be at 5000 or so when the 15% notification comes on which sounds about right.
Interesting though. when we had our '04 Element, I believe the oil change interval(back before they had oil life monitors) was 7500 miles...
I remember in the old days, I was told to always change the oil at 3000 miles.
over time, that has certainly increased.
heck, the Porsche Cayenne we traded for our element had an oil/filter change interval of 20,000 miles on synthetic oil....wow....
checked the manual here is the quote
Based on the engine operating
conditions and accumulated engine
revolutions, the onboard computer in
your vehicle calculates the remaining
engine oil life and displays it as a
percentage.
I just hit 2750 miles, 50% oil life.....
Update - 3,040 Miles, 40% oil life.
my 2009 just clicked 23,000 miles and Ive only changed the oil 3 times. doing the math im getting about 7600 miles on an oil change. I drive all interstate 32 miles each way for work and then on sundays I make a trip every week thats 45 miles each way.
thank goodness im moving this week which will cut my miles to 15 each way to work.
1 - 13 of 13 Posts
