I think they are 3175 size bulbs. I bought some white light bulbs at wal mart I think they are called xenon white or something. I think they were $4.44. They are much nicer IMO than the stock bulbs. Hope this helps.
No empirical evidence, just manufacturers' info.j_m_m said:Have you ever replaced those lights? I think there is a misconception among light manufacturers about what size goes in the map lights. I believe that it is 3175, I also double checked the package on the bulbs I used in there.
Very interesting indeed. I put footnotes on those numbers for now.lwclancers said:JMM you are right. I too went looking for 3022 at Advanced Auto with my burnt out bulb in hand...low and beyond 3022 to skinny, 3175 just right.
Whats funny is there is no way 3175 fits the dome lights...pulled them out, much longer than the map lights, although appear to be the same thickness.
Why not just pull out a map bulb and a dome bulb and compare them? then snap some pics and post them for a definitive answer for everyone?kevs said:Okay, just to confirm...the 3175 in 39mm will fit in both the Dome/Trunk Light as well as the Map Light?
I was a bit confused after I read this thread and went out to check the bulbs myself.
The Dome/Trunk Lights are noticeably longer than the map lights, but is it confirmed that the 3175 39mm bulb fits all 4 places?
I'm getting ready to buy some bulbs and want to be sure before order. Thanks!
The silver part of the bulbs should have numbers/markings on them. Are you able to read that? Not being a wisea$$, I can't always read those things.kevs said:Alright, I just went outside and compared, but I don't have my camera on me.
The Dome/Trunk Lights are way too big for the map lights.
The Map Lights are way too small for the dome lights.
What to do now?
