I recently installed the UHaul hitch on my 2007 EX AWD. I also purchased the T-One 118465 from etrailer.com. Got it installed fine at both ends and plugged in the trailer to test.
Running lights work fine on all 4 corners plus side markers. Turn signal and brakes work fine on the passenger (right) side, but do nothing on the driver's/left, whether or not the running lights are turned on.
I called etrailer and they sent me a second 118465 which arrived today. I swapped out both the under-dash unit and the harness in the cargo area, but got identical behavior on the trailer.
I checked the contacts are clean, and obviously the bulbs are fine because they turn on nice and bright when the running lights are engaged. So I'm a bit stumped.
I can send back both units for a refund and buy the Honda harness but I wanted to see if there was anything else I should test beforehand. Any ideas?
thanks,
twj
thanks,
twj
