The 2005 Element only came in Ralley Red and there was no EX-P, which came out in 2006. The 2006 Red is Tango Red Pearl.That looks great. How does it handle and where did you get the kit?
I really wish we had a 4wd E...![]()
they are fine in front...lots of room...except top of tire to bottom of spring mount is less than 1/4 inch clearance but that clearance will not change since both the tire and spring perch are in fixed locations....That looks awesome. Can you elaborate on the tire rubbing issues? is it because the 225 is too wide or too tall?
Your current rims have a 45mm off-set, go with a set of wheels with around a 40mm off-set and you have a lot more inside clearence.they are fine in front...lots of room...except top of tire to bottom of spring mount is less than 1/4 inch clearance but that clearance will not change since both the tire and spring perch are in fixed locations....
yea i know...but i dont want to spend money for rims....its just my daily...a set of small wheel spacers will do the same thing for a lot less money...and like i said its not rubbing....just not much clearance...but thanks for the suggestions...Your current rims have a 45mm off-set, go with a set of wheels with around a 40mm off-set and you have a lot more inside clearence.
Chief
