After driving the car for a few miles and breaking several times, the front end starts making a popping noise. This only occurs when making a complete stop (under 20 mph). I have taken it to the dealer, a big o tire, and pep boys and neither have been able to find a definate problem. It started several months ago and is getting louder. The E has 90k miles on it now. Any suggestions would be great. Im thinking about replacing the strut assembly to see if that helps.
Maybe a CV joint? at 90k it wouldn't be uncommon. They start out just clicking, then crunching and popping? Its worth a check? Mine is snap cracking and popping right now, bringing it in this week.
Check your swaybar end links they may be worn out and poping when the weight shifts forward when your stopping.
ours has done that since we got it. I think it's the break pads loose in the calipers.the honda dealer is useless for any thing but emptying my wallet and damaging my car.
Discussion Starter #6
Thanks for the suggestions. The E has 95k miles on it now so I think it is time to change the struts and everything that goes along with it. While they have everything taken apart I will have them check the pads and calipers as well as all the other parts. I also ordered some bfgoodrich A/T TA KO's so we will see if the combination of struts, tires, and a good lookover will cure the problem. Off subject, I was wondering if anyone has been able to lift their element 1 or 2 inches. I know they make 3 inch kits but that seems extreme considering I never go off roading and am doing it for the looks and just to have incase the need is ever there (to go off-roading).
