Programming new remote
44709 Views 38 Replies 17 Participants Last post by  nacranym
Hi you guys,
Thank you! You were all so helpful in my earlier query about purchasing a new keyless remote entry thingie.
I did indeed get one on eBay. It was great! So much less $$! But I'm confused about how to program it. The Element manual (2008 ) only says, keyless remotes must be programmed by the dealer. My seller disagrees. Here are the instructions the seller emailed me:
Here is the instruction:
Note:
Entering the programming mode cancels all learned keyless remotes, so none of the previously programmed
remotes will work. You must reprogram all of the keyless remotes once you are in the programming mode.
You must complete each step within 5 seconds of the previous step to keep the system from exiting
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNOCK button on one of the remotes. (An unprogrammed remote can be used for this
step.)
3. Turn ignition switch to LOCK (0)
4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used in step 2
5. Turn the ignition switch to ON (II)
6. Press the LOCK or UNLOCK button the same remote. Make sure the power door locks cycle to confirm you
are in programming mode.
7. Press the LOCK or UNLOCK button on each remote you want to program. Make sure door locks cycle
after you push each remote button to confirm system has accepted the remote.
8. Turn the igniton switch to LOCK (0) to exit programming mode.
9. Test remote(s)
The exact number of cycles on which remote, is confusing to me from the above instructions. Here's what I *think* they mean--?
It sounds like you would go through the cycle (steps 1-3) a total of 3 times with the first remote.
Then you do it again (still the same, first remote) and see if the power door locks cycle--?
And then (without turning the ignition key again) you push the lock or unlock button on the 2nd remote? and see if the door locks cycle?
And then you exit the whole thing by turning the key off?
Aaah! Please advise! I am leaving in about 30 hours for a long trip, and I'd love to have 2 remotes available just in case we happened to lose one.
Also--Does anyone happen to know--If you lock the E without pushing the button twice to activate the alarm--Does the alarm automatically turn itself on? Or could you enter the vehicle with the spare key (no remote)?
Thanks everyone!
Happy E-ing! :)
21 - 39 of 39 Posts
My real question is, are you reading any of the posts in this thread???
Freddy the Element seems to understand everything I am saying.
When I typed this "Adding the chip to the immobilizer portion of the E
can not be done without the proper software/computer."
I didnt pull
it out of my cookie jar. If you would do some real reading, you will see that
what I said has already answered your question. If you do some real reading
you will see that what I said has been confirmed by people who work at Honda,
other E owners that have had this done, and myself. I watched them do it
for my flip key. There is a member on this site whos username is Locksmith.
(I will give you one guess to what he does for a living.) He has also confirmed
this. If you could program the immobilizer chip with a couple of turns of a key,
why would everyone here be at the dealership spending $50 - $100 to get it
done?? This is a group of very intelligent, resourceful, frugal, and passionate
Element owners. Please do some searching and some reading, you will see
what I am talking about.
Sorry, I have read about 200 pages of this forum, and I have a hard time keeping it all straight, excuse me for needing clarification. I did read all of the posts in this thread, and up until this post of yours no one said how exactly the keys were programmed. That was the answer I was looking for.
I HAVE been doing research and reading, I am not a stupid person, I am "sorry" I missed the above info, thank you for taking time out of your day to type it out for me.
Now I have the answer that I was looking for, and was unable to find just reading though hundreds of posts.
All the information in this site is a little overwhelming, an most of the time I only have my droid to read it on, so that makes it even harder to keep track of what threads are what.
Gesh, maybe give the noobs a break now and again.
For the record, I just want to add that I tried the "put in the first key, put in the second key, put in the new key" thing and it doesn't work. Have to have the key programmed by a locksmith or dealer. I imagine they update the immobilizer with software, that's it.
It's been awhile, but I finally got my new remote fob sorted out, here's what happened:
Got the remote/key blank from "artiway" on Ebay. The remote programmed perfectly, took it to a locksmith to cut and program the key. The locksmith cut the key ($30) but could not program it -- and the key would only go into the ignition and driver door, not the back hatch or passenger door. Found another locksmith who could program it ($30 again), but he couldn't make the key work on the other two doors. He claimed the blank key was a valet key and would never work on all doors.
Dissatisfied, I wrote to artiway on Ebay and he said the key was not an valet key and had been improperly cut -- if I would mail him an original key and the improperly cut key, he would make it right at no cost. He's in Taiwan so I was hesitant, but I took the chance. For an extra $30, he promised he would forward me an additional remote/key fully cut and programmed as compensation for my experience.
It took about 5 weeks to send the key and get it back, but I'm happy to say that artiway did everything as promised -- both new keys work flawlessly in all respects. So all's well that ends well. Should have just sent the key to him in the first place!
Hello all,
I ahev been trying to program my new remote that I got form Ebay. I trued many times and it does not work.
My Element is a 2005 LX. Is this model comes with the receiver for the keyless remote?
Thanks for your help in advance?
No.
10 characters
Hello all,
This link shows how to tell if you have one or not.
http://www.re-vision.com/element-j/images/keyless/01.jpg
LOL Thanks for your help!! now I know what I need.
Programed keyless entry
Hey Fellow E drivers,
This worked great. just got a remote from Ebay for $35 bucks, and now my 2006 ex has keyless entry! I bought the car 5 years ago, and just made the last payment on it two weeks ago. I bought it with out the keyless remote, and wanted to get it ever since. except the dealer told me it would be about $150 bucks! so i put it off forever.... thanks to this forum, i finally did it, and at a great price! thanks so much
Big lesson about Honda - They sell the cars for one price and then they suck you dry with highly inflated service and parts prices forever after.
Both of my remotes have stopped working after only 1 1/2 years (lock works, unlock doesn't). If I buy new remotes from ebay and do the reprogramming as explained here, does this programming affect my ignition key in any way?
Edit to add: Just went to ebay and want to clarify that I am talking about the remote on the key fob; not the combination key/remote that I didn't know existed.
Nope. They're two separate systems. Remember that you DO have to program all of your remotes at the same time and the remote in the combination key/remote can be swapped out if the remote goes bad so you won't need to have a new key cut & programmed. I already had to do that once - bought a replacement (used) Pilot key on Ebay and then swapped the remote in to the old key. If you open the case for changing the battery, the whole transmitter falls out. This was a surprise for my local dealer who insisted we needed to buy a new key and have it programmed again. $200 plus turned into $8 and two minutes with a screwdriver.
Programming a subaru fob to an Element
Hey guys, do you think I can program my old subaru fob to my recently purchased Element? It was an 04 forester and now I have an 03 Element.
I used the instructions for my '05 and they eventually worked! I have a question about it though. Is it supposed to make a ding noise when hit the unlock button? I noticed there was noise that matched the lights in the cab flashing. Is that normal?
you mean a noise similar to what happens when you leave the lights on and open the door?
and the noise/beep is heard as you open the door just after unlocking?
the vehicle is telling you that the lights are on and you've opened the door.
of course the lights are only the parking/marker/side lights and they're only on very briefly to acknowledge your request to unlock the vehicle.
solution: unlock the vehicle when you're further away from it, so that the lights have already done the flash thing when you open the door. of course, if you do it when you're so far away that it takes more than 30 seconds for you to open the door, you'll find that the door has relocked itself. so, choose your distance for using the remote wisely. <grin>
I figured it out that it was making the noise when the door was open, I can be kinda slow at times. At first I thought I had done something wrong programming it. 8) Pretty excited to have a keyfob after owning the car for over a year.
Not working
I'm sure i'm doing something wrong or just too impatient but I can't get it into the programming mode. I know it has keyless entry because it came with it and I lost the original key fob. I've got two new ones and I've tried with both.
Do I just keep trying? After three times, should i take the key out to start over or just keep repeating steps 1-3 until i get a clunk?
I think I'm following the instructions to a tee.
Worked for me!
Thanks for the good directions! I bought 3 Ridgeline keys online, took them to the dealer, who said it wouldn't work. Told him to do it anyway.
They cut them and successfully programed the immobilizer, but were unable to program the door locks on more than one key. I took them all home, and followed these directions, and they all worked.
One bit that took me a second to figure out... when it says to press the lock OR unlock, that is an OR, not an AND. I did both lock and unlock with each cycle, and none of the keys programed right. Then I realized it was an OR, and just used the lock button each time and everything worked great.
When I did it to add a 3rd remote, I felt like Daniel in the Karate Kid movie.
Key on, click, key off. . .
I ordered a new keyless entry fob and followed the above instructions and this did NOT work at all for me. We still have the old fob which is hanging by a thread and it still works if you lean heavily on the worn out/cracked unlock button so we will stick t that. But the point is the directions for reprogramming a new on (part 08E61-S5D-1M001) do NOT work for our 2003 Honda Element.
did the new fobs you acquired have the same FCC ID as the old fob that is barely hanging on?
i ask because a lot of 2003 models didn't come with remote lock/unlock when they left the factory, so dealers installed whatever they thought was appropriate, which may not be compatible with fobs from later years.
21 - 39 of 39 Posts
