1 - 2 of 2 Posts
2005 honda element. Ive encountered an issue when shutting the car off. The key will not turn all the way to the off position to remove key. However the key does come out in the "1" position which leaves the electrical system on. When I remove the "+" battery cable the ignition switch will go to the "o' position...whats causing this? It's a struggle to get the key out . Lately its impossible?
I've seen simular threads but nothing as specific. Any advice?
Theres a Sticky about the ignition cylinder pins...
Yours are toast.
1 - 2 of 2 Posts
