I would like to clean up my phone bracket area (proclip mount) and add additional input functionality with multiple 3.5 mm inputs being made available.
Installing additional 3.5 mm inputs is easy enough. But can someone tell me what the current AUX input wiring connections are like to the OEM head unit?
The main goals here:
- Maintain an AUX input in place on passenger side of dash per OEM
- Add additional AUX audio inputs, possibly put them on a multi-switch selector for source selections or other
Need to know how I can add the wiring. Anyone know what the backside of the OEM is for the AUX input...I'm assuming it's hardwired in. Next option would be to split the aux cable (pull the original, install splitter (simple male to female connection) behind original location, install a new 3.5 mm receiver in dash, run the new additional line to...where desired.
Looking for input for all you dudes that have pulled the HU and/or the AUX port.
