1 - 8 of 8 Posts
after seeing the posting on how to remove the overhead console, i decided to hardwire my radar detector ( 1st speeding ticket just 7 days into E ownership). the cord from my detector has 2 wires, but there's only 1 wire going into the dome lights. how do i wire it up? :?
I used an "add a circuit" fuse tap. I took power from the power window relay fuse. I then routed the power cable up the side of the dash and thru the "A" piller. My Valentine One is attached to the sunvisor via a clip.
one of the wires is the power wire the other is a ground splice power wire int the power wire for map lights then for the ground wire crimp a loop connector on and loop around one of the mounting screws under the light against body metal
not sure but when you take light out there should only be one power lead to lights the ground for lights will be chassis (screw) ground also. let me know if you have a prob ill take mine apart and check it out and hook up my radar while im at it lol
1 - 8 of 8 Posts
