CRV fan fits!!!!
I would like to add a few things I encountered while performing a condenser fan replacement.. (the instructions above were invaluable!!!!)
First - the terminology had me confused. BOTH fans are supposed to come on when the AC is on. NEITHER fan seems to be needed if the engine runs cool. So it was hard for me to determine which was which. That made it hard to order a replacement. ("The one on the passenger side" didn't seem to matter to the parts counter guys) I finally figured it was my condenser fan - the passenger side. And that fan was hard to locate. What I did discover, by accident, is the the Honda CRV fan was a perfect match for a replacement, and was cheaper too!!!
Other than that, the difficulties I encountered were small but time consuming. Wire clips were hard to get to, hard to remove and hard to replace. The bottom plugs were a bear to get right. NOTE - if you broke the bottom plug clip when removing it, be sure to remove the broken part from your plug before trying to replace it on the new housing. This took me 20 minutes on my back to discover and remedy.
Lastly, I think it might be better (though I didn't try this) to remove that top-to-bottom brace thingy at the hood latch point rather than at the bottom. That way you could avoid all of the wire tabs that attach to that support altogether, and avoid the need to get on your back to remove the bottom 10mm bolt. .
