I recently purchased an 06 Element . The radio seems function,search stations etc. but no sound from the speakers , could it be the amp or a fuse ??
disconnect?
my radio/amp (element 2003) has a similar problem: when disconnected from the battery and reconnected again, everything works fine but NO SOUND! whatever. After a long search I found out that disconnecting and connecting again was the solution, sound came back. It seems like there is a switch somewhere which toggles by disconnecting from the mains. Nobody could explain it, but it still works that way: after a flat battery I have to disconnected once more to get my sound back. Maybe this helps?
