1 - 1 of 1 Posts
Anyone else have one of these (other than T-Mac! http://www.elementownersclub.com/forums/showthread.php?t=10331&highlight=radio+controlled )? I bought mine four years ago and haven't used it but twice, and when I went to try it out again I found the battery in the car is dead, and can't be re-charged from the base. However, when its on the base charging station, the steering and wheel turning can be activated with the controls indicating the R/C is working. I get almost zero volts when reading the charge points on the car.
Minor prying won't budge the chassis from the Element top, to get at the battery, and I'm afraid to apply much pressure.
Anyone else run across this and found a solution? I need some Elemental R/C action again!
EDIT: Got it open with a small screwdriver! Now to replace that battery!!! Woohoo!
1 - 1 of 1 Posts
