The car was running and I turned on the AC to Max. The lights dimmed, the engine almost died then the radio went out. Now the radio has an error message displayed? Anyone have any ideas why this happened? And or how to fix the error message? Thanks much...
Sounds like you might have a problem with your battery or alternator. I would test your battery to see if it is still good and if it is then check your alternator for output. Your mechanic should do this free of charge as it is simple and they would love to take your money if they find a problem.
since its an 08, its probably still under the warranty.
You probably need to re-enter the radio code. Open your glove compartment, there should be a sticker on the left side of the it. 6 digit code.
