The rear air deflector is an option, it does not come standard with the EX. Also depending on the color of your Element, the rear air deflector may not match too well.
We had orded the rear air deflector, and it is only made in silver. It does not match much else on the Element, ours being Green. The dealer was good, he asked me if I really wanted it, after it came in, as he did not think it looked good.
The same thing on the rocker panel trim. It matches the rear air deflector. Did not look good on the car, so we did not have the dealer install it.
If you check the color in the pic, it is the only color (at this time) the air deflector comes in.
From driving it, you really don't need it (you may want it, but don't need it). The shape of the Element helps to really keep the back windown pretty clean, even driving thru snow and rain.
