1 - 8 of 8 Posts
Can anybody tell me what bulb type goes in the high center rear brake light? (OK, so I'm lazy and haven't pulled the cover off yet.)
The lighting catalogs don't have the Element listed yet, but they say the 2002 CR-V uses a type 7440 bulb. Since the Element shares so much with the CR-V, I suppose it's possible that the Element uses the same bulb.
[quote:6280cece93="canyonero"]Read the F :!: :!: :!: ing Manual
Just kidding - IT humor :wink:
Check the owners book, I think it is in there. If not, it at least tells you how to replace all the bulbs in the E
Good Luck
Homer[/quote:6280cece93]
I did, well before I asked here. The listing for the lights is like nothing you find anywhere else.
I agree, the manual is very unenlightening as to what bulbs are used. If someone can tell us, I would liek to know as well so as to have some spares on hand.
[quote:dae68495c5="isketerol"]I agree, the manual is very unenlightening as to what bulbs are used. If someone can tell us, I would liek to know as well so as to have some spares on hand.[/quote:dae68495c5]
Well, I went out and took the light out to look. Guess what? Nothing on the bulb or holder. And, the process of taking it out broke the filament. (Cheap bulb). Now I have to make a trip to the auto parts store, so I'll find out the hard way.
I actually wanted to replace the center brake light with an LED "bulb", but I now see that this is not possible, since the bulb holder mounts the bulb at an angle, and the LEDs would not be shining at the driver behind the car. Oh, well. :?
reedpc said:
[quote:3db41afd3b="isketerol"]I agree, the manual is very unenlightening as to what bulbs are used. If someone can tell us, I would liek to know as well so as to have some spares on hand.[/quote:3db41afd3b]
quote]
The high center brake lamp is definitely a 7440.
1 - 8 of 8 Posts
