. . . I'm hoping to hear that the interior trims do not need to be removed to complete the job. :domokun:
The shop manual I have (2004) says the interior trim has to be removed to access the nuts holding the leading edge of the pane. I think the only difference in door construction between 04 and 07 is the seat belt anchor.
If you are intimated by taking off the trim, it's probably better for you to have a glass shop do the work, but if you're not, the replacement steps in my manual (abbreviated) are:
- (if present) remove upper seat belt anchor cover, remove anchor bolt ( two washers, 2 collars and a bushing).
- pull the weatherstrip out as necessary,
- pull out on the top of the (lower) door panel to release the hooks,
- pull out on the rear door trim panel to detach the clips (3, one at top, one on leading edge, one near the center of the panel. )
- pull out on the glass cover lock, remove bolts to the door, remove lock from door
- hold the glass, remove the 4 nuts
- transfer the lock parts to the new glass
- install in reverse order
- check for squareness, lock operation, leaks, wind noise.
