2008 Element LX
Hello everyone,
Long-time Element owner here, but new to the forum.
Rear propeller shaft failed last week. '08 Element LX. U-joint broke and rear of shaft was clanging around under there. Fortunately, I was close to home. Towing bill wasn't too bad... Removed shaft and have been driving in 2WD. No problems with that.
As many of you know, u-joints are not serviceable, OEM replacement shaft assemblies run $600 - $700. R&R of assembly takes 1/2 hour tops. Lots of aftermarket options available. This one not the cheapest, but looks good:
12 month warranty, u-joints replaceable and can be greased.
Anyone have any experience with this part or company?
Muchas Gracias!
Hello everyone,
Muchas Gracias!
No experience with this one, but it looks like it might be a decent alternative. I replaced my '05 EX driveshaft at 219k back in 12/17, with one from NAPA, that cost just over $ 300, and have put 30k on it since.
2008 Element LX
I like NAPA. Bought front calipers, pads & rotors there recently. Good quality stuff! The only shaft they have available right now is $655. Even with 15% off, that's $556. If the NAPA part was still $300 I would snap it up, but with a $200+ difference, will give it some thought... 🙂
2008 Element LX
I thought about a used one. You might get lucky and get one that had been replaced. I don't see too many Elements under 200K around here, so I went with new. After a bit more research, I ordered the one above from Wholesale Import Parts. Will post pics and such when it comes in.
Thanks so much guys, for your responses!
