I replaced the tail light bulbs a couple months ago on my 2005 ex as well as 2 of the fuses and when they stopped working then, then again recently I replaced all 3 fuses but they don't turn on now. Any ideas on where else to look to troubleshoot?
Have a uhaul hitch? Caused my rear running lights to go out due to a cheap/fast wire tap. I just took off the tail light assembly and removed the taps. Then switched fuses and that did the trick. Does the fuse blow?
I do not have a hitch...I just checked the wiring under the rear light housing and it's all connected. I replaced all the fuses a couple days ago...
