I've got about 70k on the stock struts and the rears are blown. the rear rebounds excessively when you bounce it. The fronts are still perfectly fine.
I do alot of road trips in the summer and and the car is usually heavily loaded when I do. I can't lower the suspension because of specific bike rack that I use. I don't want to have my bikes dragging on the ground.
SO, Is there a stiffer than stock spring that I can use to keep my stock ride height, or am I stuck with stock springs.
Also are there any adjustable OEM style struts available? If I am able to find stiffer springs, I'll need to be able to adjust the rebound accordingly.
