I always liked the lights on the mirrors of the Toyota FJs.So here's what I did tonight while watching the Phils loose the world series. I picked up these dual mode three wire surface mount LEDs on Ebay. They had a chrome ring that I painted satin black and come with 3M self adhesive backing. They are low amber as marker lights and High for the turn signals and hazards. I pulled the rear view mirror off the E and disassembled it to route the wires (that I shielded) through the mirror following the OE wiring (be careful not to pinch it anywhere). After reassembling the mirror I checked it to make sure all was working OK. I then remounted the mirror and pulled the door panel. Routed the wires down through the door (avoiding the window track) and out through the door jamb wiring boot. then fished the loomed wire out through the fender and wire tapped it into the turn signal bulb lead,
