Remote opens E but doesn't lock?
768 Views 4 Replies 3 Participants Last post by  TheAntirice
Any ideas, both remotoes do the same thing.
E run's and cranks fine even thou we've had a week of rain.
Only thing I can think of is if the door pin in one of the doors isn't triggering to tell the car the door is fully closed. Does your dome light circuit work when you open the door? Indicator on the dash say the door is open? I know with the oem keyless entry it won't lock if the door is open..not sure about the hatch but maybe start investigating that. That's all I got :)
TheAntirice!!!
You hit it, the rear hatch wasn't closed all the way.:)
Many Thanks!!
Like the guy above me said, check your doors. Also check to make sure your hatch is closed all the way. It'll keep you from locking up as well. Just went down and tried mine with a door closed but not all the way and it's doing exactly what you're describing.
::EDIT::
Oooohhh, just a few seconds too late. :)
TheAntirice!!!
Many Thanks!!
Right on! Glad to help :D
