Honda calls that plug a diagnostic connector. It is an expensive tool from Honda that comes in a kit.I’ve heard there is a company that makes resistors that plug into the disconnected SRS connector to make the SRS module think the removed component is still there. We have a diag tool here that does the same but it’s pretty bulky.
Good question that I didn't think of. I am waiting on the response.So, maybe a dumb question, but does the drivers side airbag work if you reset the system… without the passenger seat in the car?
No. The SRS system does a self diagnostic every time the key is cycled on. If it picks up a malfunction (in this case the missing passenger seat belt buckle) it will illuminate the light and disable the entire system. You need to be able to trick the SRS unit into thinking all components are present and functional. Only then can you clear the light and keep it off.So, maybe a dumb question, but does the drivers side airbag work if you reset the system… without the passenger seat in the car?
It would be great if you told us what the resistance was.I’m going to be making some airbag bypass connectors this weekend to trick the SRS unit into thinking the airbag inflators are still there. They should work for the seat as well because the connector is the same and the resistance spec is the same. I’ll test it and report back. If they work would you be interested in one?
Diagnostic procedures on both the airbags themselves and the seat belt tensioner (buckle) call for use of the the Honda SRS simulator tool in the 2 ohm ports. As such, I’ll be making the bypass connectors using 2 ohm resistors and original OEM connectors. They’ll snap right in where the airbag inflators (or seat belt buckle) would have been plugged in.It would be great if you told us what the resistance was.
Cool, thanks for the info.Diagnostic procedures on both the airbags themselves and the seat belt tensioner (buckle) call for use of the the Honda SRS simulator tool in the 2 ohm ports. As such, I’ll be making the bypass connectors using 2 ohm resistors and original OEM connectors. They’ll snap right in where the airbag inflators (or seat belt buckle) would have been plugged in.
Yes, I’d be really interested! Thanks
