After a search of the EOC forum, I failed to find the info, so perhaps one of you knows how or where to get the following info:
I want to remove the dash piece (the piece that has the covers for the instruments and the left defrost vent) that covers the instrument cluster.
It looks like it just pops out, but I'm not sure where to start (and thus breaking the pop-in connectors.
Thanks in advance,
Justo
It's very simple,all you need to do is pop off that side piece of your dash that you see when your door is open.Afterwards look to the top,you will see a small phillips screw...just remove it.Then grab a hold of the entire cluster cover piece and firmly pull,it will pop off.:)
Thanks for the quick response! Sounds easy enough.
- Justo
