Better Clutch
Well there are no real performance clutches available for the E. As far as "better" is defined, just stay away from cheap aftermarket parts. Daikin/Exedy clutches makes the OEM clutch as is always a good choice for a stock replacement. If you are looking for a more robust clutch you will need to change the flywheel to an RSX piece. E-bay has kits for about $300 with a stage 2 clutch and a lightweight flywheel. The lightweight flywheel will let your engine spool up quicker (very important for turbo engines, not so much on non-turbos) giving you better throttle response and quicker acceleration. It can be a little intimidating to drive for newbie M/T users, but seasoned veterans have no problem adapting to the way the engine revs up. Have fun and let us know what you think of the change.
Steve
