see attachment
Here are some instructions.
Removing Heater Temp &
Mode Dials: ’03 Element DX
If you’ve ever installed an accessory A/C kit in a
’03 Element DX, you’ll probably agree that it’s a
real challenge to remove the control dials without
botching the panel. Here are some handy tips to
make the job easier.
To remove the temperature control dial:
1. Turn the outer ring to the full hot position.
2. Pry on the inside (not the outside) of the ring
at the 6 o’clock position.
3. Turn the outer ring to the full cold position,
and pry again on the inside of the ring at the
6 o’clock position.
To remove the mode control dial:
1. Turn the outer ring to the defrost position.
2. Pry on the inside of the ring at the 4 o’clock
and 8 o’clock positions.
3. Pry on the inside of the ring at the
12 o’clock position.
By prying on the inside of the ring, you confine
any damage to those parts that would get replaced
with new parts from the A/C kit.
This info has already been added to the A/C
Installation Instructions, AII 24107. To make sure
you’ve got the latest
