Did you buy any shrouds to cover the projector. You know, to make it look pretty? I couldn't tell for sure from the pictures. If so which ones?this is the exact kit i got; it has everything you need, from all of the mounting brackets to the nuts and bolts.
http://www.theretrofitsource.com/pr...d=227&osCsid=587ed1d7dc781584bfade93c72ae9e15
Those look like gatling gun shrouds.Did you buy any shrouds to cover the projector. You know, to make it look pretty? I couldn't tell for sure from the pictures. If so which ones?
How did you get them lined up so good? I'm having an issue with my cutoff on my H1's,Hey guys
sorry ive been away here
as far as painting the reflector i decided against it; IMO i dont really like the look.
i wanted to make it look somewhat oem.. if you know what i mean
as for a write up it was just:
take apart the housing (write ups on how to already)
slide projector in h4 hole, and use the locking screw that came with it to tighten it up.
close housing
power up :-D
it is the same as the ones that some have gotten from ebay.
there is no cutting or anything needed. just a direct bolt up.
i went with these for the fact that i didnt want to have to cut the housing/ reflector. and this is TOTALLY reversible
