generic brand from ebay..mounted the brain box in the spare tire compartment and ran the wires along the floor to the passenger side panel that covers the rear shock absorber.behind that cover you will find power(wht/rd)and reverse light (grn/blk)wires,then just find a good ground and your all done.Also the wires coming from the sensors come in through the factory harness at the tailgate,just cut a small hole in the rubber grommet and feed your wires through then silicone the hole you made in the grommet.
