Hi,
I have an 06 E and over the past 6 months i've noticed a moderately rough idle at start when I fist start her. it lasts about 3-5 minutes, is worst if the AC compressor is on, and in those first few moments if I get up to speed and then brake to a stop or near stop sometimes it will stall.
There is NO check engine light. The mechanic said there was no error code. The timing belt was OK, there were no vacuum leaks and the throttle body was clean and working...
I'm stuck.
Dave
Yep.. Valve adjustment. New spark plugs would be a good idea.. And there is no timing belt so I don't know how it checks out to be ok..
