1 - 8 of 8 Posts
Long story short, I adjusted the exhaust valves on my '03 E two days ago and noticed that after I opened up the valves to 0.30 mm lash, the tappets can be heard more loudly during idle. I decided that was probably not unusual because otherwise the engine purred along nicely, and after driving around all day I felt like it ran better, and I even felt like I had improved my fuel mileage a bit.
Unfortunately, as of turning the key when I got in this afternoon to drive home, the engine suddenly idles very rough, struggles at low RPM and the check engine light flashes non-stop.
Two days of normal, no-check-engine-light improved fuel economy and then BAM! it suddenly feels like I lost a cylinder.
I removed the valve cover again to see if something slipped, but everything is still on point at 0.30 mm. As far as my performance of the valve adjustment, I didn't cut any corners whatsoever, and my mechanic brother assisted me. Replaced the valve cover gasket and the gasket sealer. Even repainted the valve cover. I reused the spark plugs, but they can't be any more than 15 months old, and they show no evidence of fouling. All four of the ignition coils were replaced a year ago next month. Everything torqued to spec.
I'm not sure whether the valves are a red herring and my problem has more to do with the ignition system or not. Anybody ever experience something like this? Did I just completely break it?
Thanks in advance for feedback!
Start by disconnecting one coil pack at a time. Let you know if you have a cylinder that is not firing. Check the injectors in the same manner. If you are still stymied use a compression gauge and check to see that you are near 130 psi. And as Edward asked - did you get any codes?
Discussion Starter #5
Re:
all replies
Yep.
Turns out the tappets noise was a red herring.
Like y'all suggested, I started pulling the ignition wires off the coils one by one this morning. First coil wasn't firing at all. Replaced it with an old coil I had lying around and problem solved.
Lesson learned: don't buy cheap knock-off ignition coils.
Yep.
Glad it worked out for you. Happy trails.
The Quality Rule
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
This quote has been attributed to a few different people, but lived by soo many.
1 - 8 of 8 Posts
