I would like to install Wayfinder and am looking for a method of routing wire through A-Pillar into engine compartment. I have removed cover, but see no clear method of routing wires. Any help would be appreciated.
Dave
Thanks for the reply, but I am a little unclear about something. Is the big rubber plug you push out the same one that the Hood release cable goes through? If so why do you have to push it out as there is already a hole in it for the release cable. Or is there another plug behind that one? Also how do thoses clips come out. I played with them a bit but was concerned about breaking them?
Ah Heck maybe I should tell the wife I need a trip to Hawaii for a consult!!
Dave
I have tried and tried to plug out the plugs in the fender to no avail. I'd like to know if there's a secret as well.
Those rubber plugs in the fender are a 2 stage design. If you look at them you will see 2 little indents on the edge. When I first tried to get these out I was just a little too gentle. Carefully pry up the center of the plug then you can pry out the main part of the plug.
HTH
Dave
