Okay so I've owned my E for 6 years now, I call her Tupperware. I've always trusted my mechanic with EVERYTHING. But due to difficult financial times I'm having to do somethings myself.
Current issue: Rubbing / Grinding Noise
Where: Front or middle
When: While coasting without brake or gas. Straight or Turning
Notes: Pitch change proportionate to speed
What I've tried: Left Rear Caliber (Mechanic's Advice)
(Caliber Piston was Jammed)
Transmission Drain / Refill x2
Suggestions I haven't explored: All 3 Motor mounts and Trans Mount
(will be trying this soon)
(need a good tutorial)
Welcome, Jjharmon.
If it varies with speed while coasting in neutral, you can rule out motor mounts. (There are tutorials on those when you choose to do it, though; search for relevant threads.) It could be something as simple as a misaligned dust plate. Try jacking up all four wheels and turning each by hand to see if you can reproduce the scrape.
Caliper.
