I had my AVIC-D3 installed professionally about 2 years ago. XM reception is crumby since the antenna is mounted on the driver's side corner of the dash all the way up under the windshield. You can see the wire threaded through between the dash and the windshield. I've slowly worked up the confidence to move the satellite antennas myself by reading these boards extensively.
I've located the XM box (GEX-P920XM), which they installed under the driver side near the hood release. To see it you have to look up into the underside of the dash but it's easily reachable. I unplugged the antenna and it's in a one-wire harness about 1/3" on each side.
My question is, how do I get the antenna out of this position without dismantling the entire dash since the harness is too thick to pull through between the dash and the windshield?
Thanks all!
Thanks all!
