I want install a satellite radio dock in my 2007 SC. I want the install to be clean with an absolute minimum of wires visible. I also want the satellite radio to be down away from my field of vision, the display is very bright at night and it is distracting. I have found in another post how to directly wire another circuit for the radio, so I don't think that will be a problem. The issue I am having is trying to figure out the nuts and bolts of mounting it.
My preferred position would be on the center console forward of the drink holders. I think this would be ideal since it can be operated by either the driver or passenger and seen by both. It also seems that any wires that have to be run would be at their shortest from this distance.
My questions are:
1. What is the best way to get the audio output from the satellite radio to the radio in the car? I want to use the auxiliary jack and was thinking about snaking the cable through the console to the jack in the storage compartment and plugging in there.
2. Power, I think have this figured out, I found a few posts about adding a circuit to the car and it does not look very complicated. However, does anyone see possible issues with running wires to and from the location?
3. Mounting, I have done a lot of research on these forums, but most of the mounts used seem to be on either side of the radio. If I can mount the radio where I intend to I just want a simple mount that can be either glued or screwed to the console and allows the display to be tilted. Any suggestions?
Here is a picture of where I want to mount the satellite radio. Any help or opinions would be appreciated. Oh, and the radio in the car is the stock radio and I don't intend to change it out.
My questions are:
