I have successfully installed a basic stereo system with 2 speakers in my DX. This may be a simple task to a Car Audio Veteran, but to me it has been a learning experience. For the benefit of any others who want to try this, here's a list of components I used:
Jensen 4X25watt AM/FM/Casette
removed from recently departed Dodge Shadow (RIP)
Car Stereo Connector
Scosche HA028
from Wal-Mart
$6.99
Metra Dashworks Speaker Wire Harness Adapter
DW-7800SH
from Circuit City (installation dept.)
$6.99/pair
Pioneer 6.5" (16cm) Speakers
TS-163P
from Best Buy
$24.99/pair
Metra Dash Kit (placed order, should get it in a few days)
99-7863
from River Oaks Car Stereo (www.installer.com)
$18.95
Obviously this is not top of the line gear, I might have been able to get better prices, or bought all this stuff at the same place, but there ya go. Here's a a brief description of the process:
1) Prepare the deck by installing the wiring harness with crimp connectors, the wires are color-coded so it's very simple.
2) Remove the bezel from the dash, VERY CAREFULLY! I used this document as a reference:
http://www.handa-accessories.com/element/elementdxtuner.pdf
Read the part about wrapping a shop towel around the screwdriver, and pull the screwdriver towards you DO NOT TWIST IT! My bezel was a little stubborn, and I ended up leaving a couple small marks on the plastic :x
3) At this point you will see the stereo connection and the antenna connection attached to the blank piece of plastic hooked onto the bezel. Connect these to the stereo.
4) Attach the speaker wiring harnesses to the prongs on the back of the speakers, using the harnesses makes the connection very easy, and you won't have to cut any wires in the E. The connectors are different sizes so its easy to match up + and -
5) Pull off the speaker grilles (refer to the diagrams in the .PDF above) These come off much easier than the bezel, I removed them without tools.
6) At first it looks like just a hole in the door, but the wires are in there, Honda has made it very easy for you. Inside the door, just below the speaker hole, you should see a grey connector with two wires, which will be taped to a larger bundle of wires. Pull the speaker wires free. Connect the speaker to the wire, and then screw the speaker into the door. There are three holes which correspond to the holes already drilled in the speaker (I assume this is true for any round 6.5" speaker, other shapes and sizes may require drilling)Replace the speaker grilles and you should be set. Repeat the last few steps if you want a pair in the back doors too.
7) Install dash kit - I don't have mine yet, but I'll post again when I get it.
The components and installation process described above worked for me, and I hope it works for you, if you have any questions, I'd be happy to clarify. Big thanks to all the replies in my previous posts on this subject.
Happy driving and happy listening!
Scosche HA028
from Wal-Mart
$6.99
DW-7800SH
$6.99/pair
TS-163P
from Best Buy
$24.99/pair
99-7863
$18.95
