I have a whining sound that increases with engine rpm so yesterday I pulled the serpentine belt off to see if one of the accessories that runs off of it (altenator, AC, water pump, belt tensioner) felt unusual. The only thing I found was slight side to side play in the tensioner pulley. I was looking at replacing it but I see Honda sells just the bearing, has anyone replaced just the bearing vice the entire tensioner assembly? I have no belt squeal so I believe the tensioner portion is working fine.
Any suggestions?
Thanks,
Patrick
Any suggestions?
Thanks,
Patrick
