This has been a confounding issue for me and I'm hoping someone has any insights. So, I replaced both Strut Hats; both A-Arm Compliance Bushings; and only the drivers side Inboard Axel Boot (it was ripped, all others were fine) on my 2003 Element AWD EX with 99K. When I did the driver's side boot, I thoroughly cleaned and packed the Inboard Joint and rollers with grease to spec and it slid nicely into the transmission on install. I did not replace the tranny oil ring as it looked fine, though I have one arriving today.
Except for two (2) minor hiccups, the work went well and I followed the Service Manual to a T. My two mistakes were:
A) Passenger Side: I didn't properly support the passenger side knuckle when removing the strut and A-arm (one at a time, so I figured Axel would be supported by one or the other), so on reinstall I had to give the Axel, which I did not remove, a good shove inward to move the rollers up the Inboard Joint so I could align the ball joint to the A-Arm. The Inboard Joint Boot stayed in place and the Inboard Joint did not come off the Intermediate Shaft whatsoever.
B) Driver's Side: When I removed the driver's side Axel, I took the whole assembly off with the Knuckle and promptly dropped it on the concrete floor (they call me Butterfingers). It landed Inboard Joint face down right on the very tip of the shaft extending off the Inboard Joint. There's a little bit of damage on the face of this shaft where it contacted the floor, but none on the splines or anywhere else on the Inboard Joint (see pics). Again, I repacked the Inboard Joint; the marked Rollers went nicely back in place; and the entire Axel slid and clicked nicely in place.
When I test drove my E, all seemed well; no vibration; no clicking, clunking, etc. But, when I engage Park (P) on the transmission lever/shifter, it doesn't hold the E. It's like it's in N-neutral despite being in P. I topped off the transmission fluid, which was very low, and tried to reset Park with that trick of the key in the slot on the shifter cover; all to no avail.
I now have the driver's side Axel out again (by itself) and still don't see anything wrong with the oil seal or the splines, etc. inside the transmission case (see pics). I will replace the seal anyway at this point.
My questions: 1) Would the marring on the very tip of the driver's side Inboard Joint cause Park not to work? It doesn't even appear that the tip of the Inboard Joint Shaft has any job or serve any major mechanical function, correct? 2) Is it worth taking the passenger side Axel out to see if there's a problem there, even though that Axel was not removed and stayed pretty much undisturbed for this whole job?
I would replace the entire driver's side Axel or even just the Inboard Joint, but they are not available from Honda anymore. NOS versions are $1,000, and I'm not putting a new Chinese Axel on the E. It also doesn't make sense to put a junkyard Axel from a 300K E when mine only has 99K.
Sorry for the long post, I just wanted to layout every step of the job in the hopes someone has any insights. I be truly grateful for them! Happy St. Paddy's day. P
