Once the wire was behind the dashboard I then diassembled the dash. I removed my painted instrument cover, removed the instrument gauges and had full access to behind the dash. I worked the wire up to the instrument area and to the left of the radio.
I disconnected the battery since I knew I would be wiring things, plus I didn't want my alarm to go off or ruin something. lol
Next I wired in the Add-A-Circuit and my Power Socket. From previous posts I knew that Fuse #18 was what others had used so I used it as well. Those little fuses are near impossible to get out... for some reason either the Element doesn't come with a fuse puller or I couldn't find one! Note to self, purchase a fuse puller!
Next I removed the radio so I could get behind it and install the PIE and the RCA cable. I still can't stand the stupid design of the radio trim U shape piece... a pain in the a$$ to remove! Once it was off I could remove my Bracketron and Panavise brackets. I had my iPod on the Panavise on the left side and an old cellphone used to be on the Bracketron. I moved the iPod to the right of the radio on the Bracketron and the Panavise would hold my Starmate Replay.
I next ran the Starmate power cord from the power socket up behind the dash and into the instrument cluster opening with the antenna. I had the RCA cable there as well. Next step would involve some trim work of the dash panel to make room for the cables to come through. I wasn't going to drill a hole or anything, since it would have been an ugly mess. I decided since the wires were fairly thin I would just trim a slit on the far right side until the cable fit. Once I did this I discovered that the dash panel actually sat in a channel that would pinch the cables, so I needed to trim this as well. This piece is actually part of the dash itself, it is just in front of where I have the wires zip-tied to the dash.
I used a sharp knife for all of this cutting and trimming, as I didn't feel the need to break out the Dremel.
Now that I had my 3 wires in the general vicinity of where the radio would be I installed the Starmate mounting plate to the Panavise and installed it temporarily for the first of many test fittings. I only wanted enough wire sticking out of the dash to allow me to connect/disconnect the Starmate. So this took a handful of fittings, removing the dash panel, zip-tieing the wires, etc. I finally got it to the point where I am very happy with it.
I connected the PIE and RCA cable together and installed the CD Changer cable to the PIE. Then I tucked the PIE above the A/C duct behind the radio so it was out of the way of the radio. Put the radio in place and reconnected all of the cables for it.
