Got that Trans mount swapped out yesterday. What a pesky part that was to get back in. IT took a lot of maneuvering and patience and brute force to get the bolt holes to line back up with the frame. The best method was to bolt in the back bottom bolt on the mount first. Pretty much followed alinghi12 Transmission Mount Replacement Instructions thread. With the exception of not removing the battery tray at first. That was a big mistake. I ended up backing the wrench up to the tray and getting the wrench stuck.... then in my attempts to remove it, I broke the ratchet.
The battery tray has 3 bolts up top, and 2 down low. To get the through bolt out, I removed the three up bolts on the tray, and the most forward bottom tray bolt. This allowed me to leverage the tray just enough to slide the bolt and wrench out. I used an open end box wrench to put it back in.
Here's the old and the new. I really couldn't see the tears until I had the part out. I just went on a hunch and did the swap. kinda glad to see it was starting to rip out and I had not gone through all the trouble for nothing.
Extentions, Extentions Extenstions. This job needs lots of extentions, did I say extentions yet? Yeah, you need em. This is just to illustrate to do the back bolt first!
50815-SCV-A84 is the part number.
AND - Another 6 months of XM radio for $30.
