After seeing the abysmal review on the CCM lift kit, I came across the Honda Rescue Garage based out of Morrisville, NC. The guy knows his stuff and has videos on the Element lift as well as addressing the CV joint issues. I decided to give the 2 inch kit a go, found a shop to help me with it and addressed my popping issue.
Turns out it's just old struts needed replacing, so I ended up with new struts all around, the lift, tie rods, end links, with new wheels (16x8 +20 offset) and grabber ATX (245/75/16).
I was never able to find good info on this so hopefully this helps the rest of you wanting a slight lift for meaty tires!
